Zum Hauptinhalt wechseln
Milwaukee Hex Impact Driver 2656-20 Trigger Assembly Replacement
Was du brauchst
  1. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Battery: Schritt 1, Bild 1 von 2 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Battery: Schritt 1, Bild 2 von 2
    • Squeeze the red buttons on the battery.
    • While squeezing the red buttons, slide the battery forward and out to remove it from the device.
  2. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: Schritt 2, Bild 1 von 2 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: Schritt 2, Bild 2 von 2
    • Lay the impact driver on its side.
    • Remove eight 16 mm and a single 19 mm screws using the T10 Torx Screwdriver.
    • Separate the two halves by pulling up on the top half.
    • Make sure that the half with the screw heads Is facing up during this process. This will ensure that the components do not fall out.
    • Lay the top half to the side.
  3. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Trigger Assembly: Schritt 3, Bild 1 von 2 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Trigger Assembly: Schritt 3, Bild 2 von 2
    • Remove the two 6 mm screws on the back of the brush card assembly using the T10 Torx screwdriver.
    • Move the two wires out of the way.
  4. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement: Schritt 4, Bild 1 von 2 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement: Schritt 4, Bild 2 von 2
    • Gently pull up on the trigger assembly to remove it from the case.
  5. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement: Schritt 5, Bild 1 von 1
    • Remove the trigger assembly from the device.
Abschluss
Troy Conrad
97 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 25
Insgesamt: 1,193
