Zum Hauptinhalt wechseln
Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement
Was du brauchst
  1. Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement, Milwaukee Hex Impact Driver 2753-20 Cover Removal: Schritt 1, Bild 1 von 1
    • Using the Torx T10 screwdriver, remove the six 17 mm screws on the outside of the handle.
    • Remove the two 40 mm Torx T10 screws near the bottom of the cover.
  2. Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement: Schritt 2, Bild 1 von 2 Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement: Schritt 2, Bild 2 von 2
    • Carefully remove the cover.
    • If there is buildup from sawdust or sediment it might be a little difficult to take apart.
  3. Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement, Gear Case: Schritt 3, Bild 1 von 1
    • Set the cover aside so the drill body is visible and can be accessed.
    • The gear case is the silver cylinder part with a black tip in the top of the drill.
  4. Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement: Schritt 4, Bild 1 von 2 Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement: Schritt 4, Bild 2 von 2
    • Grip the gear case in one hand while holding the body of the drill with the other.
    • Pull outward to remove.
    • Remove carefully, being mindful of the connecting wires. Damage to these wires can cause permanent damage to the drill.
  5. Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement: Schritt 5, Bild 1 von 1
    • Check the connection from the motor to the trigger.
    • Check that the connection to the circuit board is intact.
    • If both connections are intact, the gears inside the gear case assembly may be jammed and need to be replaced.
  6. Milwaukee Hex Impact Driver 2753-20 Gear Case Replacement: Schritt 6, Bild 1 von 1
    • A replacement part can be found on the Milawukee Tool Website under Part NO. 14-30-D012.
Abschluss
Kaylee Rose
268 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 21
Insgesamt: 1,658
