Zum Hauptinhalt wechseln
Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement
Was du brauchst
  1. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement, Milwaukee Hex Impact Driver 2753-20 Cover Removal: Schritt 1, Bild 1 von 1
    • Using the Torx T10 screwdriver, remove the six 17 mm screws on the outside of the handle.
    • Remove the two 40 mm Torx T10 screws near the bottom of the cover.
  2. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement: Schritt 2, Bild 1 von 2 Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement: Schritt 2, Bild 2 von 2
    • Carefully remove the cover.
    • If there is buildup from sawdust or sediment it might be a little difficult to take apart.
  3. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement, Reverse Button: Schritt 3, Bild 1 von 2 Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement, Reverse Button: Schritt 3, Bild 2 von 2
    • Locate the black forward/reverse button underneath the chuck.
    • Pull the button gently towards you to remove it from the trigger assembly.
  4. Milwaukee Hex Impact Driver 2753-20 Reverse Button Replacement: Schritt 4, Bild 1 von 1
    • Using replacement part NO. 45-24-D013 (forward/reverse shuttle), follow the steps of this guide in reverse order.
Abschluss
Alex Larson
243 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 731
