Zum Hauptinhalt wechseln
Milwaukee Hole Hawg 1675-1 Field Replacement
Was du brauchst
  1. Milwaukee Hole Hawg 1675-1 Field Replacement, Motor Brushes: Schritt 1, Bild 1 von 1
    • Ensure that the drill is unplugged.
    • Position the drill so that it is on its side.
  2. Milwaukee Hole Hawg 1675-1 Field Replacement: Schritt 2, Bild 1 von 3 Milwaukee Hole Hawg 1675-1 Field Replacement: Schritt 2, Bild 2 von 3 Milwaukee Hole Hawg 1675-1 Field Replacement: Schritt 2, Bild 3 von 3
    • Remove the brush cap with a flathead screwdriver.
  3. Milwaukee Hole Hawg 1675-1 Field Replacement: Schritt 3, Bild 1 von 2 Milwaukee Hole Hawg 1675-1 Field Replacement: Schritt 3, Bild 2 von 2
    • Pry up on the copper brush holder with a screwdriver or spudger.
    • Continue lifting up the copper brush holder to remove the brush.
    • Repeat on the opposite side.
  4. Milwaukee Hole Hawg 1675-1 Field Replacement, Field: Schritt 4, Bild 1 von 2 Milwaukee Hole Hawg 1675-1 Field Replacement, Field: Schritt 4, Bild 2 von 2
    • Position the the drill upright and remove the four 19mm Torx T15 screws securing the motor cover.
  5. Milwaukee Hole Hawg 1675-1 Field Replacement: Schritt 5, Bild 1 von 3 Milwaukee Hole Hawg 1675-1 Field Replacement: Schritt 5, Bild 2 von 3 Milwaukee Hole Hawg 1675-1 Field Replacement: Schritt 5, Bild 3 von 3
    • Remove the motor cover and withdraw the armature.
    • Take note to not lose the washer that sits on top of the armature.
  6. Milwaukee Hole Hawg 1675-1 Field Replacement: Schritt 6, Bild 1 von 2 Milwaukee Hole Hawg 1675-1 Field Replacement: Schritt 6, Bild 2 von 2
    • Remove the black insulator ring.
    • Remove the two 45mm Torx T15 screws securing the field to the drill.
  7. Milwaukee Hole Hawg 1675-1 Field Replacement: Schritt 7, Bild 1 von 3 Milwaukee Hole Hawg 1675-1 Field Replacement: Schritt 7, Bild 2 von 3 Milwaukee Hole Hawg 1675-1 Field Replacement: Schritt 7, Bild 3 von 3
    • Position drill on its side.
    • Remove the four 19mm Torx T15 screws.
    • Remove the two 25mm Torx T27 screws.
    • Remove the top portion of the handle.
  8. Milwaukee Hole Hawg 1675-1 Field Replacement: Schritt 8, Bild 1 von 2 Milwaukee Hole Hawg 1675-1 Field Replacement: Schritt 8, Bild 2 von 2
    • Lift the switch up and away to allow room to work.
    • Uncrimp the wire connector on the yellow field wire attached to the switch to disconnect it.
  9. Milwaukee Hole Hawg 1675-1 Field Replacement: Schritt 9, Bild 1 von 1
    • Lift the field out of the device, feeding the yellow wire through the handle.
Abschluss
Colby Green
183 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 23
Insgesamt: 592
