Einleitung
Has your Milwaukee Hole Hawg stopped responding when you squeeze the trigger? If so, it could be a faulty switch and in need of replacement. Take a look at the Milwaukee Hole Hawg 1675-1 Troubleshooting Page. The switch makes a connection when depressed that supplies power to the motor for use. Over time connectors inside the switch can fail or the switch housing can break. All you will need for this repair is a T27 and T15 Torx bit along with a #0 flathead screwdriver.
Was du brauchst
Remove the top portion of the handle.
Lift up on the switch and disconnect the wires.
Use a #0 flathead screwdriver to release tension on the wires.
2 weitere Personen haben diese Anleitung absolviert.
