Zum Hauptinhalt wechseln
Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement
Was du brauchst
  1. Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement, Motor Brushes: Schritt 1, Bild 1 von 3 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement, Motor Brushes: Schritt 1, Bild 2 von 3 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement, Motor Brushes: Schritt 1, Bild 3 von 3
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device and remove (6) 5 x 18mm screws with a T-20 screwdriver.
    • Remove (4) 5 x 14mm screws. with T-20 screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: Schritt 2, Bild 1 von 3 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: Schritt 2, Bild 2 von 3 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: Schritt 2, Bild 3 von 3
    • Hold the device so the gray gearbox assembly faces directly towards you.
    • Remove the four screws with a T-20 screwdriver.
    • After removing all screws, use a small plastic opening tool to slide the gearbox assembly forward.
  3. Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: Schritt 3, Bild 1 von 3 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: Schritt 3, Bild 2 von 3 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: Schritt 3, Bild 3 von 3
    • Gently remove the upper clam shell.
    • Slide the motor and gearbox assembly out the front of the device and set it aside.
    • Abrupt pulling may damage the motor brushes. Please remove it with caution.
    • The brushes may need to be compressed in order for the motor to be removed.
  4. Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: Schritt 4, Bild 1 von 2 Milwaukee Impact Wrench 9070-20 Motor Brushes Replacement: Schritt 4, Bild 2 von 2
    • Remove the brushes from the mount by pulling the brush body directly upward.
    • Disconnect the blue wire from the lower brush.
    • Disconnect the white wire from the upper brush.
    • Reconnect the wires to the new brush and replace them back into the mount.
    • The brushes may need to be compressed in order to slide the motor back into position.
Abschluss
Ein Kommentar
Wear to find brushes for impact
Laurie Hathaway-Ashby - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 5
Letzte 30 Tage: 17
Insgesamt: 646
