Einleitung
This guide will walk through the steps to replace the forward/reverse shuttle on the Milwaukee M12 2407-20.
Was du brauchst
Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
Remove metal clip located at the base of the drill, where the battery is to be inserted.
Use both hands to lift and remove the gear case assembly from the shell casing.
Set the gear case assembly aside.
While holding the shell in one hand, pull the end of the broken forward/reverse shuttle out of the casing.
Set the broken forward/reverse shuttle aside.
2 weitere Personen haben diese Anleitung absolviert.
