Einleitung
This guide will walk through the steps to remove the service housing set (outer casing) on the Milwaukee M12 2407-20.
Was du brauchst
Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
Remove metal clip located at the base of the drill, where the battery is to be inserted.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
