Zum Hauptinhalt wechseln
Milwaukee M12 2407-20 Shuttle Spring Plate Replacement
Was du brauchst
  1. Milwaukee M12 2407-20 Shuttle Spring Plate Replacement, Outer Casing: Schritt 1, Bild 1 von 1
    • Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
  2. Milwaukee M12 2407-20 Shuttle Spring Plate Replacement: Schritt 2, Bild 1 von 1
    • Remove metal clip located at the base of the drill, where the battery is to be inserted.
    • You may need to use a spudger if the clip is too difficult to remove with your fingers.
  3. Milwaukee M12 2407-20 Shuttle Spring Plate Replacement, Shuttle Spring Plate: Schritt 3, Bild 1 von 3 Milwaukee M12 2407-20 Shuttle Spring Plate Replacement, Shuttle Spring Plate: Schritt 3, Bild 2 von 3 Milwaukee M12 2407-20 Shuttle Spring Plate Replacement, Shuttle Spring Plate: Schritt 3, Bild 3 von 3
    • Use both hands to lift and remove the gear case assembly from the shell casing.
    • Set the gear case assembly aside.
  4. Milwaukee M12 2407-20 Shuttle Spring Plate Replacement: Schritt 4, Bild 1 von 2 Milwaukee M12 2407-20 Shuttle Spring Plate Replacement: Schritt 4, Bild 2 von 2
    • Remove the forward/reversing shuttle to gain access to the spring plate.
  5. Milwaukee M12 2407-20 Shuttle Spring Plate Replacement: Schritt 5, Bild 1 von 1
    • Remove the spring plate and insert replacement spring plate.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 20
Insgesamt: 1,342
