Zum Hauptinhalt wechseln
Milwaukee M12 2407-20 Speed Selector Lever Replacement
Was du brauchst
  1. Milwaukee M12 2407-20 Speed Selector Lever Replacement, Outer Casing: Schritt 1, Bild 1 von 1
    • Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
  2. Milwaukee M12 2407-20 Speed Selector Lever Replacement: Schritt 2, Bild 1 von 1
    • Remove metal clip located at the base of the drill, where the battery is to be inserted.
    • You may need to use a spudger if the clip is too difficult to remove with your fingers.
  3. Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: Schritt 3, Bild 1 von 3 Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: Schritt 3, Bild 2 von 3 Milwaukee M12 2407-20 Speed Selector Lever Replacement, Speed Selector Lever: Schritt 3, Bild 3 von 3
    • Remove the unit from the housing assembly and set the housing assembly aside.
  4. Milwaukee M12 2407-20 Speed Selector Lever Replacement: Schritt 4, Bild 1 von 1
    • Use a spudger to pry the broken speed selector lever off the assembly.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 17
Insgesamt: 1,571
