Zum Hauptinhalt wechseln
Milwaukee M18 2606-20 Gearbox Replacement
Was du brauchst
  1. Milwaukee M18 2606-20 Gearbox Replacement, Chuck: Schritt 1, Bild 1 von 3 Milwaukee M18 2606-20 Gearbox Replacement, Chuck: Schritt 1, Bild 2 von 3 Milwaukee M18 2606-20 Gearbox Replacement, Chuck: Schritt 1, Bild 3 von 3
    • Rotate the chuck counterclockwise as far as possible to loosen from the base.
  2. Milwaukee M18 2606-20 Gearbox Replacement: Schritt 2, Bild 1 von 2 Milwaukee M18 2606-20 Gearbox Replacement: Schritt 2, Bild 2 von 2
    • Remove the 28 mm inner screw holding the chuck onto the drill using a Phillips #3 screwdriver.
    • Rotate the screw clockwise to loosen it.
    • The inner chuck screw is reverse threaded which is why it needs to be rotated clockwise.
  3. Milwaukee M18 2606-20 Gearbox Replacement: Schritt 3, Bild 1 von 2 Milwaukee M18 2606-20 Gearbox Replacement: Schritt 3, Bild 2 von 2
    • Insert an Allen wrench into the chuck and tighten the chuck onto the wrench.
    • The Allen wrench will be used for leverage when removing the chuck.
    • When the chuck is tightened it could make a clicking sound. This is fine and is not causing any harm to the drill.
  4. Milwaukee M18 2606-20 Gearbox Replacement: Schritt 4, Bild 1 von 3 Milwaukee M18 2606-20 Gearbox Replacement: Schritt 4, Bild 2 von 3 Milwaukee M18 2606-20 Gearbox Replacement: Schritt 4, Bild 3 von 3
    • Rotate the Allen wrench counterclockwise to remove the chuck.
  5. Milwaukee M18 2606-20 Gearbox Replacement, Gearbox: Schritt 5, Bild 1 von 2 Milwaukee M18 2606-20 Gearbox Replacement, Gearbox: Schritt 5, Bild 2 von 2
    • Using the T3 Torx screwdriver, remove the seven 18 mm screws from the handle area of the case.
    • Using the T3 Torx screwdriver, remove the two 21 mm screws from the top of the case.
  6. Milwaukee M18 2606-20 Gearbox Replacement: Schritt 6, Bild 1 von 3 Milwaukee M18 2606-20 Gearbox Replacement: Schritt 6, Bild 2 von 3 Milwaukee M18 2606-20 Gearbox Replacement: Schritt 6, Bild 3 von 3
    • Using the T3 Torx screwdriver, remove the four 20 mm screws from the front of the case.
  7. Milwaukee M18 2606-20 Gearbox Replacement: Schritt 7, Bild 1 von 2 Milwaukee M18 2606-20 Gearbox Replacement: Schritt 7, Bild 2 von 2
    • Peel back the sticker at the bottom of the drill handle.
  8. Milwaukee M18 2606-20 Gearbox Replacement: Schritt 8, Bild 1 von 2 Milwaukee M18 2606-20 Gearbox Replacement: Schritt 8, Bild 2 von 2
    • Open the case by sliding the opening tool all the way around the case to pry it apart.
  9. Milwaukee M18 2606-20 Gearbox Replacement: Schritt 9, Bild 1 von 2 Milwaukee M18 2606-20 Gearbox Replacement: Schritt 9, Bild 2 von 2
    • Lift the gearbox slightly and pull away from the motor to remove it from the case .
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 21
Letzte 30 Tage: 77
Insgesamt: 3,920
