Einleitung
Use this guide to replace a damaged gearcase insulator on a Milwaukee Reciprocating Saw 6538-21-B36B (2010).
The gearcase insulator is a component that protects the gear case in power tools. It helps prevent damage to the gear case by providing a layer of insulation and cushioning if damaged use this guide if it needs to be repaired.
Pull up on the shoe release lever until it's perpendicular to the gearcase insulator.
Remove the gearcase insulator by folding over the rubber, dislodging the insulator from the red shift lever, and pulling it off.
