Zum Hauptinhalt wechseln
Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement
Was du brauchst
  1. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement, Power Cord: Schritt 1, Bild 1 von 2 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement, Power Cord: Schritt 1, Bild 2 von 2
    • Use a TR20 Torx screwdriver to remove the five 15.9 mm screws that secure the two halves of the handle together.
    • Use a TR20 Torx screwdriver to remove the two 25.4 mm screws near the motor housing.
  2. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement: Schritt 2, Bild 1 von 3 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement: Schritt 2, Bild 2 von 3 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement: Schritt 2, Bild 3 von 3
    • Use a TR20 Torx screwdriver to remove the single 15.9 mm screw that secures the trigger mechanism.
    • Gently lift the trigger mechanism from the handle casing and unseat the power cord wires from their slotted position.
  3. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement: Schritt 3, Bild 1 von 1
    • Use light pressure to pull the white and black wires from the trigger mechanism.
  4. Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement: Schritt 4, Bild 1 von 3 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement: Schritt 4, Bild 2 von 3 Milwaukee Reciprocating Saw 6538-21-B36B (2010) Power Cord Replacement: Schritt 4, Bild 3 von 3
    • Notice the small windows on the side of the trigger mechanism; this is where the wires attach.
    • Apply pressure to open these windows with a small flathead screwdriver; this is to ensure the wires are securely in place.
    • Insert the white and black wires from the replacement cord in the sockets perpendicular to the windows.
Abschluss
Jaydon0125
355 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 14
Insgesamt: 59
