Einleitung
If the Milwaukee 2605-20 Drill is not allowing orientation switching, follow this guide to inspect and replace the forward/reverse shuttle.
The screws on this device are not easily removed.
Was du brauchst
Remove two 20.3 mm screws at the right side of the drill base using a Torx T3 screwdriver.
Remove five 20.3 mm screws on the right side of the handle using a Torx T3 screwdriver.
Remove four matte 24 mm screws on the crankcase at the rear cover of the drill (connecting the chuck to the handle) using a Torx T3 screwdriver.
Remove two 24 mm screws on the housing cover beneath the ventilation slots. These screws point into the drill.
Using a Torx T5 screwdriver bit, remove two 26.8 mm screws on each side of the drill housing cover, located beneath the ventilation slots. These screws point upwards.
Locate the forward/reverse shuttle on the drill, just behind the drill trigger mechanism.
Gently pull the trigger down and remove the damaged fwd/rev shuttle.
Eine weitere Person hat diese Anleitung absolviert.
