Einleitung
For any damage requiring replacement of the side handle case for the Milwaukee Rotary Hammer 260520 D14A 2016, refer to this replacement guide for instructions.
This guide also serves as a disassembly guide for taking apart the drill casing. Some of these screws may be stuck, especially if this is the first time the drill casing is being taken apart, so be prepared to apply some considerable amount of torque if necessary.
Was du brauchst
Remove two 20.3 mm screws at the right side of the drill base using a Torx T3 screwdriver.
Remove five 20.3 mm screws on the right side of the handle using a Torx T3 screwdriver.
Remove four matte 24 mm screws on the crankcase at the rear cover of the drill (connecting the chuck to the handle) using a Torx T3 screwdriver.
Remove two 24 mm screws on the housing cover beneath the ventilation slots. These screws point into the drill.
Using a Torx T5 screwdriver bit, remove two 26.8 mm screws on each side of the drill housing cover, located beneath the ventilation slots. These screws point upwards.
Eine weitere Person hat diese Anleitung absolviert.
