Einleitung
In the event that the battery needs to be replaced it is necessary to follow the steps of this guide to achieve this goal.
Locate the latch labeled BATT SD CARD on the right side of the camera.
Push the latch in the direction of the arrow, and it will spring open.
Insert the battery into the larger slot until the gray tab (circled in red) clicks and secures the battery.
To remove the battery, pull the gray tab back until the battery springs free.
When the battery has been removed/inserted, push the latch down, and it will lock into place.
Ein weiterer Nutzer hat diese Anleitung absolviert.
