Zum Hauptinhalt wechseln
Minolta Dimage Xt Capture Button Replacement
Was du brauchst
  1. Minolta Dimage Xt Capture Button Replacement, Casing: Schritt 1, Bild 1 von 3 Minolta Dimage Xt Capture Button Replacement, Casing: Schritt 1, Bild 2 von 3 Minolta Dimage Xt Capture Button Replacement, Casing: Schritt 1, Bild 3 von 3
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
    Frag FixBot
  2. Minolta Dimage Xt Capture Button Replacement: Schritt 2, Bild 1 von 3 Minolta Dimage Xt Capture Button Replacement: Schritt 2, Bild 2 von 3 Minolta Dimage Xt Capture Button Replacement: Schritt 2, Bild 3 von 3
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
    Frag FixBot
  3. Minolta Dimage Xt Capture Button Replacement, Capture Button: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Choosing the front half of the casing, locate the capture button on the top.
    • Using tweezers, apply pressure to the two black hooks (circled in red) while holding the button down from the outside of the case.
    Frag FixBot
  4. Minolta Dimage Xt Capture Button Replacement: Schritt 4, Bild 1 von 1
    • The button will spring free. The capture device consists of the plastic button and a small metal spring.
    • The button can be reassembled by using the tweezers to place the spring rectangle-side down on the button and snapping the button back into place.
    Frag FixBot
Abschluss
Reassemble the casing by reversing steps 1 and 2.
Clemson, Team 12-4, Benson Spring 2013 Mitglied von Clemson, Team 12-4, Benson Spring 2013
CLEM-BENSON-S13S12G4
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 77
Insgesamt: 861
