Einleitung
If you are unable to mount your camera to a tripod, the tripod socket could be broken and may need to be replaced.
Was du brauchst
With a screwdriver, remove the (7) black Phillips #00 5.0mm screws on the bottom of the camera.
Remove the bottom panel of the camera by placing your index finger and thumb on the outer edges of the panel.
Pull the bottom panel towards you, it should come off easily.
Use the tweezers to gently remove the tripod socket, and replace it.
