Zum Hauptinhalt wechseln
Minolta Maxxum QTSI Tripod Mount Replacement
Was du brauchst
  1. Minolta Maxxum QTSI Tripod Mount Replacement, Tripod Mount: Schritt 1, Bild 1 von 1
    • With a screwdriver, remove the (7) black Phillips #00 5.0mm screws on the bottom of the camera.
    • The screws are located on the outer edge of the bottom panel.
    • Be careful when removing the screws from the panel because they are easy to lose.
  2. Minolta Maxxum QTSI Tripod Mount Replacement: Schritt 2, Bild 1 von 2 Minolta Maxxum QTSI Tripod Mount Replacement: Schritt 2, Bild 2 von 2
    • Once all the screws are removed, the panel should easily come off.
    • Remove the bottom panel of the camera by placing your index finger and thumb on the outer edges of the panel.
    • Pull the bottom panel towards you, it should come off easily.
  3. Minolta Maxxum QTSI Tripod Mount Replacement: Schritt 3, Bild 1 von 1
    • The tripod socket is visible when the bottom panel is removed.
    • Remove the (3) black Phillips #00 6.25mm screws from the tripod socket.
    • When the screws are removed, the tripod socket is free and can easily be lost.
  4. Minolta Maxxum QTSI Tripod Mount Replacement: Schritt 4, Bild 1 von 2 Minolta Maxxum QTSI Tripod Mount Replacement: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use the tweezers to gently remove the tripod socket, and replace it.
Abschluss
Jordan Ellery
388 Reputation
3 Anleitungen geschrieben
Sam Houston State, Team 12-4, Blackburne Fall 2016 Mitglied von Sam Houston State, Team 12-4, Blackburne Fall 2016
SHSU-BLACKBURNE-F16S12G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 534
