Einleitung
This guide will show you how to replace the back clock button for your Minolta Maxxum STsi.
Was du brauchst
Open the back panel by firmly pressing up on the back-cover release on the lower right side of the camera.
Remove the black case by gently lifting it with your fingers and rotating counterclockwise.
Remove the five black Phillips #00 2.5 mm screws from the back panel.
Also remove the two black Phillips #00 5.0 mm screws from the back panel.
Use the tweezers to carefully peel back the adhesive foam connecting the back panel to the case and remove the panel.
