Einleitung
Have you broken or damaged the rings your camera strap attaches to? Here's how to replace them.
Was du brauchst
Use the edge of a coin to twist open the battery compartment on the bottom of the camera. (Twist counterclockwise)
Remove the black Phillips #00 5mm screw at the bottom of the battery chamber.
Open the flash and take out the silver Phillips #00 4.0 mm screw underneath it.
Open the back-cover of the camera using the back-cover release found on the lower right side of the camera.
Remove the black Phillips #00 4.0 mm screw from the inside top right section of the camera.
Remove the black Phillips #00 5.0 mm screw from the back of the film compartment.
Remove the seven black Phillips #00 5.0 mm screws from the bottom panel. The bottom panel is now free to come off.
Take out two black Phillips #00 2.5 mm screws on the right side panel of the camera.
Starting beneath the "SPOT" button, use the round side of the metal spudger and firmly pry underneath the grey top panel of the camera. Work your way counterclockwise around the camera prying at different spots until the top panel starts to come loose. Pry all the way around until you reach the "STsi" logo.
Carefully remove the right side panel by grasping it at the bottom and rotating is counter-clockwise. The top panel is now free to snap off.
Remove the four black 5.0 mm Phillips #00 screws to remove the strap holders.
