Einleitung
Replace your broken eyelet strap so that you can wear a strap with your Minolta QTsi Maxxum camera.
Was du brauchst
Once the compartment is open, grab the batteries and pull them out of the compartment.
With a screwdriver, remove the (7) black Phillips #00 5mm screws on the bottom of the camera.
Once all the screws are removed, the panel should easily come off.
Press the release button on the side panel to pop open the back piece of the camera.
Take out the (2) Phillips #00 5mm screws on the right side panel of the camera.
Remove the (1) Phillips #00 5mm screw on the left side panel of the camera.
Remove the side panels from the camera and set them aside .
Remove these (2) silver Phillips #00 5mm screws from each side of the viewfinder.
Unscrew the (4) black Phillips #00 5mm screws to remove each eyelet strap holder and replace them.
3 weitere Personen haben diese Anleitung absolviert.
