Zum Hauptinhalt wechseln
Minolta QTsi Maxxum Eyelet Straps Replacement
Was du brauchst
    1. Minolta QTsi Maxxum Eyelet Straps Replacement, Eyelet Straps: Schritt 1, Bild 1 von 1
      • The battery compartment is located on the bottom panel of the camera.
      • Use a coin to open the battery compartment of the camera.
      • Twist the coin counterclockwise in order to release the latch.
      Frag FixBot
      Kommentar hinzufügen
    2. Minolta QTsi Maxxum Eyelet Straps Replacement: Schritt 2, Bild 1 von 1
      • Once the compartment is open, grab the batteries and pull them out of the compartment.
      • There should be two batteries inside the battery compartment.
      Frag FixBot
    3. Minolta QTsi Maxxum Eyelet Straps Replacement: Schritt 3, Bild 1 von 1
      • With a screwdriver, remove the (7) black Phillips #00 5mm screws on the bottom of the camera.
      • The screws are located on the outer edge of the bottom panel.
      • Be careful when removing the screws from the panel because they are easy to lose.
      • Once all the screws are removed, the panel should easily come off.
      Frag FixBot
    4. Minolta QTsi Maxxum Eyelet Straps Replacement: Schritt 4, Bild 1 von 1
      • Once the bottom panel is removed, the one screw at the bottom of the battery compartment should be visible.
      • Remove the (1) black Phillips #00 5mm screw from the battery compartment.
      Frag FixBot
    5. Minolta QTsi Maxxum Eyelet Straps Replacement: Schritt 5, Bild 1 von 1
      • Press the release button on the side panel to pop open the back piece of the camera.
      Frag FixBot
    6. Minolta QTsi Maxxum Eyelet Straps Replacement: Schritt 6, Bild 1 von 1
      • Once the back panel is open, the chamber containing one screw should be visible.
      • Remove the (1) black Phillips #00 5mm screw inside.
      Frag FixBot
    7. Minolta QTsi Maxxum Eyelet Straps Replacement: Schritt 7, Bild 1 von 2 Minolta QTsi Maxxum Eyelet Straps Replacement: Schritt 7, Bild 2 von 2
      • Take out the (2) Phillips #00 5mm screws on the right side panel of the camera.
      • Remove the (1) Phillips #00 5mm screw on the left side panel of the camera.
      • Remove the side panels from the camera and set them aside .
      • Be careful when removing side panels. There is a plastic piece and spring underneath the left side panel that could get lost.
      Frag FixBot
    8. Minolta QTsi Maxxum Eyelet Straps Replacement: Schritt 8, Bild 1 von 1
      • When looking at the back of the camera, there should be a single screw on each side of the viewfinder.
      • Remove these (2) silver Phillips #00 5mm screws from each side of the viewfinder.
      Frag FixBot
    9. Minolta QTsi Maxxum Eyelet Straps Replacement: Schritt 9, Bild 1 von 1
      • When looking at the top of the camera, the flash hood is visible.
      • Lift the flash hood and remove the (1) silver Phillips #00 5mm screw.
      Frag FixBot
    10. Minolta QTsi Maxxum Eyelet Straps Replacement: Schritt 10, Bild 1 von 2 Minolta QTsi Maxxum Eyelet Straps Replacement: Schritt 10, Bild 2 von 2
      • The top panel of the camera should now be easy to pop off. If it is not, make sure that all screws listed in steps 3-9 are removed.
      • Lift the top panel away from the rest of the camera.
      • Be careful when removing the top panel because there are wires connected to it.
      Frag FixBot
    11. Minolta QTsi Maxxum Eyelet Straps Replacement: Schritt 11, Bild 1 von 1
      • Once all parts of the camera are removed, both eyelet straps should be visible on the top left and right sides.
      • Unscrew the (4) black Phillips #00 5mm screws to remove each eyelet strap holder and replace them.
      Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Sam Houston State, Team 12-4, Blackburne Fall 2016 Mitglied von Sam Houston State, Team 12-4, Blackburne Fall 2016
SHSU-BLACKBURNE-F16S12G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 37
Insgesamt: 785
