Zum Hauptinhalt wechseln
Minolta QTsi Maxxum Lens Replacement
Was du brauchst
  1. Minolta QTsi Maxxum Lens Replacement, Lens: Schritt 1, Bild 1 von 2 Minolta QTsi Maxxum Lens Replacement, Lens: Schritt 1, Bild 2 von 2
    • The lens release button is located on the right front side of the camera.
    • Remove the lens from the camera by pushing the lens release button.
  2. Minolta QTsi Maxxum Lens Replacement: Schritt 2, Bild 1 von 1
    • The detached module has multiple screws that must be removed in order to reach the lens.
    • Once detached, remove the (4) black Phillips #00 5mm screws from the outer rim of the module.
    • Next, remove the (2) remaining black Phillips #00 5mm screws.
  3. Minolta QTsi Maxxum Lens Replacement: Schritt 3, Bild 1 von 2 Minolta QTsi Maxxum Lens Replacement: Schritt 3, Bild 2 von 2
    • Once all screws have been removed, take the back piece off of the lens and replace it.
    • This piece should come off easily without using any tools.
    • There is film underneath the last 2 screws that are removed so be careful when taking it out because it could rip.
Abschluss
Jordan Ellery
388 Reputation
3 Anleitungen geschrieben
Sam Houston State, Team 12-4, Blackburne Fall 2016 Mitglied von Sam Houston State, Team 12-4, Blackburne Fall 2016
SHSU-BLACKBURNE-F16S12G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 622
