Einleitung
Replace your broken shutter release button so that you can take pictures with your camera.
Was du brauchst
Locate the battery compartment on the bottom panel of the camera.
Open the battery door by using a coin.
In the counterclockwise direction, twist the coin in the battery door groove to open it.
Unscrew and remove the (1) black Phillips #00 5mm screw from the battery compartment.
From underneath the flash assembly, remove the (1) black Phillips #00 5mm screw
Remove the (2) black Phillips #00 5mm screws from both sides of the view finder.
Use a metal spudger to push the button out of its socket so that you can place a new one in its place.
Eine weitere Person hat diese Anleitung absolviert.
