Einleitung
Replace your viewfinder if it breaks so that you can see through the camera to take pictures.
Was du brauchst
Remove the two batteries from inside the battery compartment by individually pulling each out.
Unscrew the (1) black Phillips #00 5mm screw from the bottom of the battery chamber.
Remove the (2) black Phillips #00 5mm screws that lie on either side of the view finder.
Abschluss
