Zum Hauptinhalt wechseln
Minolta X-370 Battery Replacement
Was du brauchst
    1. Minolta X-370 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Minolta X-370 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
      • Flip the camera so that the bottom is facing you.
      • Take a spare coin and unscrew the battery cover off.
      Frag FixBot
      Kommentar hinzufügen
    2. Minolta X-370 Battery Replacement: Schritt 2, Bild 1 von 1
      • Remove the batteries, making sure to note their proper alignment.
      Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Nick
525 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 8-7, Regan Spring 2011 Mitglied von Cal Poly, Team 8-7, Regan Spring 2011
CPSU-REGAN-S11S8G7
4 Mitglieder
28 Anleitungen geschrieben
1 Kommentar zur Anleitung
Hi there, i'm a bit stuck, in my 35mm SLR i was taking a shot and the batteries died, leaving the mirror stuck in the up position, i've changed the batteries and the release for the shutter won't click, i can't advance the film lever and so it's a sitting duck at the moment. They're brand new batteries but because the mirror is up i can't even see if the metering works. because i'm half way through a roll of film i don't want to open the back and ruin it so i'm wondering if there's any way to get the shutter to release again or to get the mirror back down, i don't mind loosing a few blank exposures but again i really wouldn't want to ruin the film. Many thanks and i hope you can get back to me,
Cameron
Cameron Tyson - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 29
Letzte 30 Tage: 124
Insgesamt: 24,945
