Einleitung
Before you start the replacement process, make sure that you have the proper repair tools, a Philips PH0 head and tweezers. You should be careful not to exert too much pressure/force on the components.
This guide will be able to walk you through the steps to replace your Mio ALPHA 2's motherboard.
Was du brauchst
Pull off the back cover of the watch
Use a pair of tweezers to flip up the retaining flap on the ribbon cable ZIF socket.
Remove the ribbon cable from its socket.
Remove the four 3.8mm JIS #00 screws from the motherboard.
Remove the motherboard with tweezers
