Zum Hauptinhalt wechseln
Mio Tab Lisciani Touch Screen Replacement
Was du brauchst
  1. Mio Tab Lisciani Touch Screen Replacement, Touch Screen: Schritt 1, Bild 1 von 2 Mio Tab Lisciani Touch Screen Replacement, Touch Screen: Schritt 1, Bild 2 von 2
    • With the help of a thin tool, lift the white edge between the upper body of the device and the touchscreen marked by the green arrows.
  2. Mio Tab Lisciani Touch Screen Replacement: Schritt 2, Bild 1 von 2 Mio Tab Lisciani Touch Screen Replacement: Schritt 2, Bild 2 von 2
    • With the help of a thin tool, separate the upper body from the bottom, inserting the tool between the two parts marked by the green arrow.
    • Open the device.
    • Remove the Scotch tape and disconnect the touchscreen connector by lifting the safety tab, located at the yellow arrow.
  3. Mio Tab Lisciani Touch Screen Replacement: Schritt 3, Bild 1 von 1
    • Use a heat source to help remove the double-sided tape.
    • Insert translation here
Abschluss
To reassemble the device, follow the instructions in reverse order.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
it en
100%
Hier starten ›
Smilzo
11.126 Reputation
39 Anleitungen geschrieben
3 Kommentare
Il tablet non si carica e non si accende e anche sotto garanzia. Come possiamo fare
Linda Cofone - Antwort
Il tablet non si carica e non si accende. Come possiamo fare è anche sotto garanzia
Valuti di portarlo in assistenza ed avvalersi della garanzia. Saluti
Smilzo -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 2,853
