Zum Hauptinhalt wechseln
Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement
Was du brauchst
  1. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Removing the stand.: Schritt 1, Bild 1 von 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Removing the stand.: Schritt 1, Bild 2 von 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Removing the stand.: Schritt 1, Bild 3 von 3
    • Lift the black cover off.
    • Remove all 4 Phillips #2 screws.
  2. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the 5 screws: Schritt 2, Bild 1 von 1
    • Remove the two 24mm Phillips #2 screws.
    • Remove the three 8mm Phillips #2 screws.
  3. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the back panel: Schritt 3, Bild 1 von 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the back panel: Schritt 3, Bild 2 von 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the back panel: Schritt 3, Bild 3 von 3
    • Lift the back and pry the back off.
    • The panel is held in with clips on the side. It needs a lot of force the take it off.
  4. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the four screws: Schritt 4, Bild 1 von 2 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the four screws: Schritt 4, Bild 2 von 2
    • Remove the four 5mm nut screws.
  5. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the 5 screws: Schritt 5, Bild 1 von 2 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the 5 screws: Schritt 5, Bild 2 von 2
    • Remove the seven Phillips #1 screws.
  6. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the cables: Schritt 6, Bild 1 von 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the cables: Schritt 6, Bild 2 von 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the cables: Schritt 6, Bild 3 von 3
    • Remove all the cables.
  7. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the motherboard: Schritt 7, Bild 1 von 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the motherboard: Schritt 7, Bild 2 von 3 Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement, Remove the motherboard: Schritt 7, Bild 3 von 3
    • Remove the four screws.
    • Pull the motherboard up and off.
  8. Mitsubishi Diamondpoint NXM76LCD Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Now you can replace it with a new one.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Padraic Hoselton
4.282 Reputation
12 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
327 Mitglieder
1.675 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 19
Insgesamt: 210
