Einleitung
With minimal handywork, you can replace the power button of your Mitsubishi Electric DD-6040 DVD player. While finding a replacement part may be difficult, physically replacing the part is an easy task, requiring only a screwdriver and some disassembly.
Sometimes, the problem is as simple as a button no longer working. Note: Be very careful handling an electronic device, and make sure that the device is unplugged before working on it.
Was du brauchst
Remove five 1.2 mm Phillips #1 screws to disassemble the DVD player.
Once the clip is unlatched disconnect the corner tabs.
Reorient and unlatch the tabs inside the device.
Remove the faceplate.
To reassemble your device, follow these steps in reverse order.
Eine weitere Person hat diese Anleitung absolviert.
