Zum Hauptinhalt wechseln
Mitsubishi T200 Screen Replacement
Was du brauchst
  1. Mitsubishi T200 Screen Replacement, Screen: Schritt 1, Bild 1 von 2 Mitsubishi T200 Screen Replacement, Screen: Schritt 1, Bild 2 von 2
    • Begin disassembling the phone by removing the phone back cover and battery.
  2. Mitsubishi T200 Screen Replacement: Schritt 2, Bild 1 von 1
    • To remove the back plate, loosen and remove the four screws by using a #00 Philips head screwdriver.
  3. Mitsubishi T200 Screen Replacement: Schritt 3, Bild 1 von 1
    • Separate the front plastic component from the motherboard component.
  4. Mitsubishi T200 Screen Replacement: Schritt 4, Bild 1 von 1
    • Take the circuit board off the motherboard.
  5. Mitsubishi T200 Screen Replacement: Schritt 5, Bild 1 von 2 Mitsubishi T200 Screen Replacement: Schritt 5, Bild 2 von 2
    • Unclip the four clips to remove the screen (connected to the clear plastic) from the circuit board.
  6. Mitsubishi T200 Screen Replacement: Schritt 6, Bild 1 von 2 Mitsubishi T200 Screen Replacement: Schritt 6, Bild 2 von 2
    • Remove the attached ribbon from the circuit board by prying open the gray plastic clip at the top right of the circuit board.
  7. Mitsubishi T200 Screen Replacement: Schritt 7, Bild 1 von 2 Mitsubishi T200 Screen Replacement: Schritt 7, Bild 2 von 2
    • We can now insert the new screen and reassemble the device.
    • Place the ribbon of the new screen into the clip on the top right of the circuit board.
  8. Mitsubishi T200 Screen Replacement: Schritt 8, Bild 1 von 1
    • Clip the new screen onto the circuit board.
  9. Mitsubishi T200 Screen Replacement: Schritt 9, Bild 1 von 1
    • Replace circut board back on top of motherboard.
  10. Mitsubishi T200 Screen Replacement: Schritt 10, Bild 1 von 1
    • Take the entire internal assembly and join it with the front plastic housing.
    • Ensure that the tops of both pieces clip into place before joining the bottom ones.
  11. Mitsubishi T200 Screen Replacement: Schritt 11, Bild 1 von 1
    • Join the phone's face assembly to the back plastic housing. Make sure you carefully insert the front into the antenna's clip first.
    • Snap the whole unit together.
  12. Mitsubishi T200 Screen Replacement: Schritt 12, Bild 1 von 1
    • Firmly replace screws into the backing.
Ziellinie
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Taylor Lewis
14 Reputation
1 Anleitung geschrieben
Ohio State, Team 1-5, Meza Spring 2014 Mitglied von Ohio State, Team 1-5, Meza Spring 2014
OSU-MEZA-S14S1G5
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 804
