Einleitung
Installing a new back panel in this television is straightforward and requires minimal disassembly.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Pull the lamp access panel off of the back panel of the television by pulling straight back on the left side of the panel near the screw then pulling to the left.
Loosen the two Phillips #2 screws securing the lamp housing to the television until the screws will swivel vertically.
Remove the following 8 Phillips #1 screws:
One 22 mm Phillips #1 in the bottom right corner of the back panel.
One 18 mm Phillips #1 in the top middle of the back panel.
Six 18 mm Phillips #1 in the rest of the back panel.
Pull the back panel off of the television by gripping the sides and rotating it down.
