Einleitung
Follow this guide to remove and replace a faulty power cord in a Mk Diamond MK660 Wet Saw.
The replacement part is 153419.
Removing the motor before the power cord is not necessary, but makes the process easier.
Was du brauchst
Loosen the plastic knob holding the saw's cutting head in place.
Lower the cutting head while keeping it steady.
Loosen the wing nut on the blade cover pivot shaft.
Remove the wing nut and accompanying washer.
Insert the provided spanner wrench into one of the four tightening holes on the inner flange behind the blade.
Use the the provided nut wrench to loosen the hex nut while providing counterforce with the spanner wrench.
Pull the entire cutting head straight off the shaft holding it in place.
Remove the eight Phillips #2 screws on the underside of the cutting head.
Remove the Phillips #2 screw holding the ground wires to the chassis.
Loosen the wires from each other.
Use a pick to slightly pry up on the crimped metal arms holding the red and orange wires together.
Repeat for both sides to loosen the connector.
Use two flathead screwdrivers to carefully pry the inner flange off the motor shaft.
Remove the inner flange.
Grab the motor with both hands and tilt it slightly upward.
While keeping the motor tilted up, pull back and up to clear the electrical components behind the motor.
Remove the motor.
Remove the electrical tape from the twist-on wire connector connecting the three white wires.
Use wire cutters to cut the angled plug off the end of the black wire so it can slide out of the power cord opening.
Use an adjustable wrench to loosen the hex nut closest to the wall plug side of the power cord.
Grab the outer sheath and slowly pull the power cord out of the cutting head.
Remove the power cord.
