Einleitung
This guide will show mobile home owners how to replace skirting that has blown down or becomes old and needs replacing. It will show the home owner how to use the panels and attach them to each other, then to the upper and lower tracks.
Was du brauchst
Find the missing pieces or order them from a Mobile Home supply company or Amazon, making sure they are the correct height.
Once you have the missing pieces, you can take each piece and start sliding them together as in Image 2.
Start by sliding the pieces together (there are what looks like a curved piece on the end of each piece).
Once attached to each other, ensure the bottom is slid into the bottom track.
Once the panels are secure in the bottom track, you will need to lift the upper track a little.
After lifting the upper track upward, you will slide the skirting in under it.
After pushing it into the upper track, you will hear a click and it should be secure in the top track.
You can secure the panels further by putting screws in the top of the panel if needed. This will help further in case of wind storms.
Eine weitere Person hat diese Anleitung absolviert.
