Einleitung
For this guide, we will be opening up the speaker and taking the defective LED wiring out so the light works again.
Was du brauchst
Use your plastic opening tool to pry the metal speaker cover off.
With the screws removed, you can now remove the top piece of the speaker to gain access to the interior.
Locate the LED wire connection and remove it from the mother board.
To make replacing the LED wiring easier, remove the speaker wire to fully disconnect the speaker from the mother board.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
