Einleitung
We will be opening up the speaker and replacing the wiring so the sound will work again.
Was du brauchst
Use the plastic opening tool to pull the metal cover off the top of the speaker.
Remove the four screws that are inside the holes on the top of the speaker.
Use a Phillips 00 screwdriver to remove the 10mm screws.
Locate the speaker wire connection and remove the wiring.
Locate the LED lighting wire and remove that as well.
Remove the positive and negative connections for the wiring to fully disconnect the wire.
Now that you have removed the defective wiring, you can install a new one.
