Zum Hauptinhalt wechseln
Modal Rechargeable Wine Opener Power Button Replacement
Was du brauchst
  1. Modal Rechargeable Wine Opener Power Button Replacement, Modal Rechargeable Wine Opener power button: Schritt 1, Bild 1 von 1
    • Carefully place the spudger under the black cylindrical ring and pry it off the top.
  2. Modal Rechargeable Wine Opener Power Button Replacement: Schritt 2, Bild 1 von 1
    • Remove the spring
    • Remove the spring guide as well to obtain clear access to the screws
  3. Modal Rechargeable Wine Opener Power Button Replacement: Schritt 3, Bild 1 von 3 Modal Rechargeable Wine Opener Power Button Replacement: Schritt 3, Bild 2 von 3 Modal Rechargeable Wine Opener Power Button Replacement: Schritt 3, Bild 3 von 3
    • Remove all four 4mm screws with a J1 Screwdriver
    • Remove the clear cylindrical cap
  4. Modal Rechargeable Wine Opener Power Button Replacement: Schritt 4, Bild 1 von 3 Modal Rechargeable Wine Opener Power Button Replacement: Schritt 4, Bild 2 von 3 Modal Rechargeable Wine Opener Power Button Replacement: Schritt 4, Bild 3 von 3
    • Apply pressure to both of the springs on the surface near the corkscrew, releasing the button port.
  5. Modal Rechargeable Wine Opener Power Button Replacement: Schritt 5, Bild 1 von 3 Modal Rechargeable Wine Opener Power Button Replacement: Schritt 5, Bild 2 von 3 Modal Rechargeable Wine Opener Power Button Replacement: Schritt 5, Bild 3 von 3
    • Remove the malfunctioning buttons from the plastic frame.
Abschluss
Lauren Spicher
101 Reputation
1 Anleitung geschrieben
USF Tampa, Team 15-4, Remmell Spring 2017 Mitglied von USF Tampa, Team 15-4, Remmell Spring 2017
USFT-REMMELL-S17S15G4
4 Mitglieder
4 Kommentare
where do you by the replacement switch?
Stan Okumura - Antwort
are there any posts for fixing the usb charging port?
Cristian Sanabria - Antwort
If the lights work, the buttons are not the problem. I can get the cork screw to turn manually, but it will not continue run beyond a few tries. Must be the motor.
tom.o@mac.com - Antwort
Could be also the battery. I will try to change the battery.
Daniel Siegenthaler -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 25
Letzte 30 Tage: 50
Insgesamt: 8,709
