Einleitung
If your mouse is intermittently disconnecting, randomly missing movements and inputs - you might have a broken or damaged mouse cable. The mouse cable carries data from the mouse to your computer. A damaged cable can result in missed mouse movements and inputs. Before starting this guide try a different connector (most likely USB) port on your computer, and inspect the connector for dirt and debris.
This guide shows an easy, step-by-step process on how to replace the mouse cable in a Glorious Model O- mouse.
The mouse should be physically unplugged from your computer prior to beginning your repair.
Was du brauchst
Using a Phillips #0 screwdriver, remove the two screws that are under the mouse feet.
Slide the base away from the top housing to avoid the front clips.
Lift the top and place it down diagonal over the base, exposing the 5-pin connector.
Use two fingers to grasp the top of the 5-pin connector under the edges and slowly lift the connector. If it is difficult, wiggle the plug slightly.
Remove the cable from around the circuit board and from the hole on the front of the mouse.
Insert the new cable's 5-pin connector plug (red) into the 5-pin connector socket (orange).
Route the new cable through the slit in the circuit board.
Route the new cable behind the pillars.
Route the cable through the hole at the front of the mouse. Some cables have a fitted square plastic piece that positions the cable, some have thermoplastic which requires the user to position it themselves.
Join the top and bottom housing together with the top around 1cm ahead of the bottom, then pull the top housing back as illustrated.
Once the two sides of the shell are together apply pressure until at least one screw is securely fastening them together.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
