Einleitung
This guide's intent is to provide instructions on how to fix this model of Shark Vacuum, by replacing a broken rotating brush. Its purpose is to educate viewers on how to do this simple repair. The detailed step-by-step instructions include hands-on illustrations throughout the process for this fix. The guide provides the quick, simple steps to locate and remove the brush for replacement. This guide saves viewers money from buying a new Shark Vacuum, by demonstrating how to fix their own.
Was du brauchst
Power-off vacuum by pressing the button on the left-rear side of vacuum until the red light is off.
Lay vacuum down with handle lying flat on the floor.
Turn the lock counter-clockwise to unlock access to the rotation brush; use a key or flathead screwdriver to fit the lock.
Remove the square brush cover to access the rotation brush.
Remove the large band from the rotation brush.
Push the band to the side and lift up the right-side of the brush.
Clean the area surrounding the brush by scraping with a putty knife before inserting the replacement brush.
To reassemble the device, follow these instructions in reverse order.
3 weitere Personen haben diese Anleitung absolviert.
