Zum Hauptinhalt wechseln
Moen Posi-Temp Cartridge Part #1112b Replacement
Was du brauchst
  1. Moen Posi-Temp Cartridge Part #1112b Replacement, Moen Posi-Temp Cartridge Part #1112b: Schritt 1, Bild 1 von 1
    • Turn the water shutoff valve counter-clockwise to the "off" position.
  2. Moen Posi-Temp Cartridge Part #1112b Replacement: Schritt 2, Bild 1 von 1
    • Open both the hot and cold taps of a nearby faucet or shower until the water no longer flows.
  3. Moen Posi-Temp Cartridge Part #1112b Replacement: Schritt 3, Bild 1 von 2 Moen Posi-Temp Cartridge Part #1112b Replacement: Schritt 3, Bild 2 von 2
    • Turn the handle of the shower valve 180 degrees until it is in the "up" or "on" position.
  4. Moen Posi-Temp Cartridge Part #1112b Replacement: Schritt 4, Bild 1 von 2 Moen Posi-Temp Cartridge Part #1112b Replacement: Schritt 4, Bild 2 von 2
    • Unscrew the handle screw with an Allen wrench.
    • Remove the handle.
  5. Moen Posi-Temp Cartridge Part #1112b Replacement: Schritt 5, Bild 1 von 2 Moen Posi-Temp Cartridge Part #1112b Replacement: Schritt 5, Bild 2 von 2
    • Remove the handle adaptor screw with a Phillips screwdriver.
    • Remove the handle adaptor simply by pulling it out.
  6. Moen Posi-Temp Cartridge Part #1112b Replacement: Schritt 6, Bild 1 von 1
    • Pull out the white key/adjustable limit stop.
  7. Moen Posi-Temp Cartridge Part #1112b Replacement: Schritt 7, Bild 1 von 3 Moen Posi-Temp Cartridge Part #1112b Replacement: Schritt 7, Bild 2 von 3 Moen Posi-Temp Cartridge Part #1112b Replacement: Schritt 7, Bild 3 von 3
    • Gently pull out the stop tube.
  8. Moen Posi-Temp Cartridge Part #1112b Replacement: Schritt 8, Bild 1 von 3 Moen Posi-Temp Cartridge Part #1112b Replacement: Schritt 8, Bild 2 von 3 Moen Posi-Temp Cartridge Part #1112b Replacement: Schritt 8, Bild 3 von 3
    • Using the Phillips head screwdriver, remove the two screws located at the top right corner and bottom left corner.
    • Remove the metal plate.
  9. Moen Posi-Temp Cartridge Part #1112b Replacement: Schritt 9, Bild 1 von 3 Moen Posi-Temp Cartridge Part #1112b Replacement: Schritt 9, Bild 2 von 3 Moen Posi-Temp Cartridge Part #1112b Replacement: Schritt 9, Bild 3 von 3
    • Slide the tip of needle-nose pliers under the notch of the retaining clip and pull the clip upwards.
  10. Moen Posi-Temp Cartridge Part #1112b Replacement: Schritt 10, Bild 1 von 3 Moen Posi-Temp Cartridge Part #1112b Replacement: Schritt 10, Bild 2 von 3 Moen Posi-Temp Cartridge Part #1112b Replacement: Schritt 10, Bild 3 von 3
    • Clamp firmly onto the brass tube with a pair of vice grips and gently but firmly pull out the cartridge.
  11. Moen Posi-Temp Cartridge Part #1112b Replacement: Schritt 11, Bild 1 von 2 Moen Posi-Temp Cartridge Part #1112b Replacement: Schritt 11, Bild 2 von 2
    • Insert the new Moen Posi-Temp cartridge.
  12. Moen Posi-Temp Cartridge Part #1112b Replacement: Schritt 12, Bild 1 von 1
    • Insert the new cartridge into the valve assembly.
    • Ensure that the H/C symbols are facing up.
    • Ensure that the notch on the brass tube is also facing up.
Abschluss
John Mendoza
205 Reputation
1 Anleitung geschrieben
York University, Team S3-G57, Melo-Thaiss Fall 2020 Mitglied von York University, Team S3-G57, Melo-Thaiss Fall 2020
YORK-MELO-THAISS-F20S3G57
1 Mitglied
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 37
Insgesamt: 1,529
