Einleitung
Oftentimes the ear cushions get ripped, and these will eventually need to be replaced. This has been known to be a very common issue when using these headphones.
If they are not ripped, they may just need to be put back into place and potentially glued down. Doing all this is very easy and will not require more than 5 minutes of your time.
Was du brauchst
Grab the ear cushion by the bottom, pull down, forward and then up to take off the cushion as a whole.
Apply glue to paste cushion back on by applying it to the edges of the earpiece.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
