Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Oftentimes the ear cushions get ripped, and these will eventually need to be replaced. This has been known to be a very common issue when using these headphones.
If they are not ripped, they may just need to be put back into place and potentially glued down. Doing all this is very easy and will not require more than 5 minutes of your time.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
  1. Grab the ear cushion by the bottom, pull down, forward and then up to take off the cushion as a whole. Grab the ear cushion by the bottom, pull down, forward and then up to take off the cushion as a whole.
    • Grab the ear cushion by the bottom, pull down, forward and then up to take off the cushion as a whole.
  2. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Apply glue to paste cushion back on by applying it to the edges of the earpiece.
    • Apply glue to paste cushion back on by applying it to the edges of the earpiece.
  4. Apply pressure on the cushion until the glue sets.
    • Apply pressure on the cushion until the glue sets.
    • Put cushion back on first
    • If this does not work, the ear cushion may need to be replaced.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Sherry Xu
116 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S4-G5, Julie Spring 2017 Mitglied von UMass Dartmouth, Team S4-G5, Julie Spring 2017
UMASSD-JULIE-S17S4G5
4 Mitglieder
3 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 3
Letzten 7 Tage: 30
Letzten 30 Tage: 123
Insgesamt: 5,471
