Zum Hauptinhalt wechseln
Monster DNA Speaker Replacement
Was du brauchst
  1. Monster DNA Speaker Replacement, Speaker: Schritt 1, Bild 1 von 2 Monster DNA Speaker Replacement, Speaker: Schritt 1, Bild 2 von 2
    • Remove the ear cushions and use a Phillips #2 screwdriver to unscrew the three 5mm screws.
    • Desolder the wires to completely remove the speaker.
    • Take note of the proper location of the wires reassembly.
    • Use a heatgun to loosen the glue holding down the speaker.
    • Be careful to take safety precautions such as gloves as not to cause injury.
  2. Monster DNA Speaker Replacement: Schritt 4, Bild 1 von 1
    • Pry the speaker out using a plastic opening tool or metal spudger.
    • Using too much force will damage the headphones and the new speaker may not go back into place properly.
  3. Monster DNA Speaker Replacement: Schritt 5, Bild 1 von 1
    • Insert new speaker and solder the five wires into corresponding positions onto the new speaker.
Abschluss
Kevin Costello
231 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S4-G5, Julie Spring 2017 Mitglied von UMass Dartmouth, Team S4-G5, Julie Spring 2017
UMASSD-JULIE-S17S4G5
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 1,588
