Was du brauchst
Lay the device on its back and unpeel the silicone base.
Unscrew the four 5mm Torx Security #10 at base.
Return the device rightside up and unpeel the black display cover over the sensor board.
Unscrew the two 3mm Torx Security #6 screws on the edge of the device.
Unscrew the two 5mm Torx Security #10 in the middle of the device.
Unscrew the two 4mm Torx Security #10 screws on the top edge.
Unscrew the six 10mm Torx Security #10 screws around the perimeter.
Remove the four 10mm Torx Security #10 screws around each individual speakers.
Loosen the two Torx Security #10 screws under the speaker using pliers or a long screwdriver.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
