Was du brauchst
Start off by unpeeling the black display cover over the sensor board.
Do not worry, the display board will re-stick when reassembling.
Unscrew the two 3mm Torx Security #6 screws on the edge of the device.
Unscrew the two 5mm Torx Security #10 in the middle of the device.
Lay the device on its back and unpeel the silicone base.
Unscrew the four 5mm Torx Security #10 at base.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
