Einleitung
The antenna receive an AM/FM radio signal. This guide will help you replace your antenna in case it is damaged.
Was du brauchst
Remove the nine 35 mm Phillips screws securing the back cover of the case.
Unplug the black and yellow wires connecting the power supply unit to the rest of the electronics:
Tilt the back cover up and remove the two 7.5 mm Phillips screws holding the antenna in place.
Fast fertig!
Abschluss
