Zum Hauptinhalt wechseln
Montgomery Ward GEN-39500 Subwoofer Replacement
Was du brauchst
  1. Montgomery Ward GEN-39500 Subwoofer Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Remove the nine 35 mm Phillips screws securing the back cover of the case.
  2. Montgomery Ward GEN-39500 Subwoofer Replacement: Schritt 2, Bild 1 von 1
    • Carefully remove the back cover.
    • Soldered wires connect electronics on the back cover to the internal electronics. Be careful not to break any connections.
  3. Montgomery Ward GEN-39500 Subwoofer Replacement: Schritt 3, Bild 1 von 2 Montgomery Ward GEN-39500 Subwoofer Replacement: Schritt 3, Bild 2 von 2
    • Unplug the black and yellow wires connecting the power supply unit to the rest of the electronics:
    • This is not necessarily required. This step is to allow the back cover more movement as you work on the inside of the unit.
  4. Montgomery Ward GEN-39500 Subwoofer Replacement, Subwoofer: Schritt 4, Bild 1 von 2 Montgomery Ward GEN-39500 Subwoofer Replacement, Subwoofer: Schritt 4, Bild 2 von 2
    • Unsolder the wires leading to and from the subwoofer.
  5. Montgomery Ward GEN-39500 Subwoofer Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the four 12.5 mm Phillips screws holding the subwoofer in place.
    • One of the screws holds down a metal cable organizer. For better cable organization after reassembly keep track of this organizer.
  6. Montgomery Ward GEN-39500 Subwoofer Replacement: Schritt 6, Bild 1 von 1
    • Remove the subwoofer.
    • The process is the same for both sides.
Abschluss
Dustin Platt
931 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 12-5, Lancaster Spring 2015 Mitglied von Cal Poly, Team 12-5, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G5
4 Mitglieder
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 111
