Einleitung
Is your vacuum's battery not working or not holding a charge? The Moosoo XL-618A has a detachable battery pack for easy charging. However, the battery can become faulty. This is a guide on how to replace the battery pack of the Moosoo XL-618A.
Was du brauchst
Remove each 15 mm screw from the four corners of the battery pack using a Phillips #1 screwdriver.
Find the wire connecting the battery to the charging port, locate the black tab at the top of the pack and pull the tab out first then the battery.
