Einleitung
If your Moosoo XL-618A vacuum is not turning on, you may have an issue with the motherboard. The motherboard is where the technological components of the vacuum come together and are powered. If you find that your vacuum is having technological issues, follow this guide on how to replace it.
Was du brauchst
Remove all nine 16 mm screws from the top motor with the Phillips #1 screwdriver.
Using a spudger, open the device along the small lines that are visible to you. Go on to pry off all other detachable objects and set aside.
Pull the motherboard underneath the top handle of the top motor out and remove the connected wires. Then replace it with a new motherboard.
